Carter dinamo
Joe
Nome: Joe
Carter dinamo
Messaggio da Joe »
Ho un alternatore per i miei 500 e devo sapere È Carter per il dinamo/alternatore per i 500 e i 126 lo stessi?
I have an alternator for my 500 and I need to know, is the dinamo/alternator carter the same for a 500 and a 126?
Indiana Joe
Are you a Ferrari???
T-rex
Re: Carter dinamo
Messaggio da T-rex »
hi joe
the carter for alternator is on fiat 126 motor type(on fiat 500R and fiat 126 of course)
the carter for dynamo is on fiat 110F motor type (on fiat 500F and fiat 500L).
so you can put whole the carter body(if I dont' mitake there are 3 carters for each group of axpiration + fan and eletric component)on every type of motor,but if you have only 1 type of carter,cause you have only a type of motor even if a lot of cars,you can't put a dynamo on a carter for alternator or conversely ,every carter is specific for its type of electric component :sad:
UNA 500 E' UN PIACERE.
Joe
Nome: Joe
Re: Carter dinamo
Messaggio da Joe »
grazie T-Rex :?
Indiana Joe
T-rex
Re: Carter dinamo
I'm T-rex.
I solve problems.
calma:::
